RCU Forums - View Single Post - T34 APV
Thread: T34 APV
Old 10-29-2007 | 07:22 AM
pattoncommander's Avatar
pattoncommander
Default RE: T34 APV
Jeff....good idea with the train smoker.[X(]..might just do that on a display setup. Think one would run on a 9v battery?
No 90mm....my scenario was a 105mm from an M-45 in korea. [:@] Photos.. the kill was easy...the "burned tires were made my demmeling the ridges meant for the rubber tires and leaving the residue in place and stabilizing with super glue. The other side was less burned and I actually burned the tires on the first two wheels with a micro torch, put all wheels in the max up position and got as much sag as possible on the tracks. Memories of ones I saw are still vivid. [] Note only the driver got out. [&o][&o]
ID:	792752   Click image for larger version
ID:	792753   Click image for larger version
