RE: Carb problem HELP!!
I see your problem!!!! the lower sleeve of the carb came off!!! and now its stuck inside the block.. you will need a new carb. That may have been your problem to begin with, that sleeve being loose will allow air in. Remove that sleeve and insert new carb...
