RCU Forums - View Single Post - KIWI PATTERN PLANE
Old 10-29-2007 | 12:51 PM
alcarafa's Avatar
alcarafa
Default RE: KIWI PATTERN PLANE
ORIGINAL: Ed Cregger
ORIGINAL: Deadstik
Rafa,
Kiwi was kitted by Sig.. not sure on the dates.. but a nice 40 sized plane.
Dan
Carolina Custom Aircraft
But not really a pattern plane.
There was a trend in the Seventies by all kit manufacturers to classify any low winged sport model as a pattern plane. This confused the dickens out of the non serious sport aerobatics folks. It was simply a marketing ploy and it worked very well - for the sellers.
For modelers, it became very confusing. After all, the box said it was a pattern model. How do you explain to someone that their Sterling Lancer, Andrews Trainermaster, etc., were not really competition grade pattern models without disappointing them? It's about the same as today's ARFs coming with fuel tanks whose necks protrude through the firewall. Anyone around in the late Sixties forward knows that this is bad engineering and leads to lots of engines being killed early in their lifespan due to fuel foaming. But try to explain this to the new modeler that trusted his ARF's manufacturer to design the model properly. Most of the time when I see a bad engine post, I know that this is the root of the problem. But who are the newbies going to believe? An old gray bearded guy, or the manufacturer?
Don't believe everything you read. These folks will say or imply anything to sell their products. That's just how the world works.
Ed Cregger
Well Ed talkiing about bad engineering, I'm surprised as most of my planes have the fuel tank near firewall, have almost never had an engine kill due to this ( was it , fuel foaming?).
In order to eventually avoid that circumstance again, where is the best place to put the fuel tank? are there any standard distance ?
Txs for you comments & advice.
BTW the KIWI died last sunday and gave it a VIKING burial in the midle of the runway, you are right ED this is no pattern plane, never came out of a nose dive and crashed in a spectacular way.
Good flights 2 you... but better landings
