ORIGINAL: rolyjr
Hi Najary,
This is great stuff, I am also busy with the ailerons, obviously not as quick as you though
. What gap do you allow between the ends of the ailerons and the wing i.e. where you have marked off on the wing for sanding/cutting?
thanks
Roly
Hi Roly
The marking is 2.5mm from the wing tip, that allows 0.9mm gap after gluing the 1.6mm balsa sheet.
Isaac Najary
