RE: My Panther
hi glen , just thinkin about your prop flexy loss , what was the end of the flexy like ? was it cut off to length from a longer flex ? i have lost some over the years but not for some time now due to two things 1 always run a shaft saver ( 1/4 wheel collets work well ) and 2 i always solder up the end of any flexy where it goes into the collet on the engine this stops the shaft from becoming that little bit smaller as it winds up under load and then spins out of the collet ,leaving the collet done up but no shaft just an idea
tony
