RE: Walkera Dragonfly #36
Brett,
Moving the tail hub to the right has the same effect as the slider moving to the left, so it will actually give you more range for right yaw. Its still the same as the stock setup - slider moves left and heli turns right, slider moves right and heli turns left. I agree with Chophop that you shouldn't need that much blade deflection just to keep the heli straight. The first thing I would suspect is that either the front tail drive pulley is slipping or the tail hub is slipping. If it's neither one of those, maybe your belt is twisted and causing a lot of drag. Or, possibly the tail blades or holders are too loose and the blades are vibrating causing turbulent airflow and losing much of their thrust.
