E-Flite 40 amp ESC
using this with a 6 series bl and a RCD3500 receiver and a Hitec Focus 4 transmitter. Here is the problem. When i try to program it and get to step 11 which is "Move your throttle control back to the CENTER position. You will hear two beeps." It never beeps twice or even beeps at all. Its like there is no brake setup at all. Since it doesnt beep or anything i tried turning battery off after adjusting it even if it didnt beep and turning it off. Also tried turning it off after i set the lipo setting to on. Everything is fine until step 11. If i try to power up the esc/motor after all it does is constantly beep and wont arm the motor. Whats the problem? I tried it in the channel 8/B and on channel 3 and the exact same thing happens.
