RCU Forums - View Single Post - Electric Osmose Building
Old 10-30-2007 | 02:09 AM
najary's Avatar
najary
Default RE: Electric Osmose Building
ORIGINAL: rolyjr
Thanks Isaac, assume that with a 0.9mm gap the covering will take up about 0.4. As a matter of interest, did your angled balsa (hinging) come out straight from the box. Of the ones I have, two are scrap as they are warped so will have to make new ones. I figured drawing a line down the middle of new stock and marking the angle on the ends, then sanding and checking with a straight edge is the way to do it. Am I on the right track, any suggestions. Thanks
Roly
Hi Roly
Mine came out straight from the box.
I suggest using the straight angled balsa on the wings/stabs (not on the ailerons/elevators).
Glue on the ailerons/elevators a new balsa sheets, about the same thickness as the original spars.
At first sand it flush with the ailerons/elevators skins, and then sand the triangle shape.
Goog luck.
Isaac Najary
