RE: Using CA
The only time I use wood glue is if I have a large piece to be glued - Like a doubler
Rather than waste all that CA, I'll run a bead of wood glue all over the doubler, but I'll keep it away from the corners and a few strategic places in the center.
Then add a drop of meduim CA to those areas and hold it in place for about 20 seconds so the CA can set.
Other than that, i use CA almost exclusively (Except where 30 minute epoxy is necessary) and avoid the fumes
