RCU Forums - View Single Post - os .61fx help
Old 10-31-2007 | 08:17 AM
bruce88123
Default RE: os .61fx help
ORIGINAL: 808_TITAN
thank you guys very much. thats what i love about this site and this hobby. if i have a question it is awnsered for every senario. i will try this things. i do use a chicken stick that i made because when i use the starter it digs grooves in to my spinner and slipps off so i figure man power will do. but once it has flown it dosent reverse i guess im putting to much prime. im useing a #8 glow plug that my LHS guy said to use and that that was the one installed on the motor. thanks again guys you are the best...
#8 plug is fine for this engine. As for the grooving - keep the spinner clean and press the starter cone firmly against it BEFORE pulling the trigger. You may need to seek out a softer or different shape cone depending on the spinner that you are using. I don't personally worry about a little starter burn on the spinner as long as the spinner remains strong.
