ORIGINAL: rolyjr
Hi Isaac,
Still busy with form the spars - coming along nicely. Great photos you put through. A couple of questions:
What is the measurement for the leading edge to the hole (leading side of the hole) you cut for the incidence adjuster on the root? Suppose the measurement is not entirely critical, but would be useful to have a reference point.
I see you have made either a hole, or an indentation on the dowel in each wing tube. Not sure what the holes/identations are for? (excuse the ignorance).
Roly
Hi Roly
The measurement is 100mm, according to the marks on the fuselage.
The purpose of the holes to prevent under pressure when you want to pull out tne carbon tube,
As you will see later, the ends off the carbon tube will also be pluged with dowels.
Isaac Najary
