RE: Threaded rod?
if you have never used solder before just remember to not get the rod red hot,apply just enough heat so the solder will start to flow into the clevis.solder will always follow heat.and like these guys said make sure the parts are clean of any oils and dirt,dont touch the ends with your fingers and sand the parts lightly to roughen up the surfaces.
