RE: Buggy shock questions...
matty when i build a shock i fill up my shock to the top then put the cap on and tighten it fully then compress it and you want to see if the shock shaft will push itself back out also try using the large shock spacer for a little stiffer as well also try a little thicker shock oil in the rear
