DP 330L Pictures
And some more pictures:
You can see the carbon fiber/nomex honeycomb mount that I replaced the standard servo mount with. Again, this was only done as a weight saving measure. The 3" long Nelson servo arm for the pull-pull exactly matches the distance between the attachment points on the control horns on the rudder. I used Rocket City offset control horns to move the attachment points at the rudder directly over the hinge line. If you didn't run the offset at the rudder, you would have to run an offset servo arm on the rudder servo(Nelson has these too) to maintain correct geometry. You can also see the really slick Nelson cable ends on the pull-pull.
