RCU Forums - View Single Post - the hyper st PRO thread!
Old 11-02-2007 | 07:56 AM
  #91
vnmsgt's Avatar
vnmsgt
Default RE: the hyper st PRO thread!
ORIGINAL: zJatoRad
Here's some info about the Spider Diff, taken from the Hyper 8.5 thread:
after checking other forums and talking with Rob from Nitrohouse here is what I have been told. The spiders are for high grip surfaces, mostly European tracks. They have less diff action then standard diffs therfore you need to use lower wt.diff fluid. With extra gears they have more natural friction and when used in the center will drive the rear harder. This make sense because the higher the diff fluid in the center the more you drive the the rear. You need to use about half the diff wt i.e. if you usually use 5k fluid standard with spiders use 2-3K. With a center spider diff I am thinking the correct set-up maybe 3kF 2kc 2kR!!
DOH![:@][:@][:@] I already put 7k in front 10k in center and 5k in rear. I read in RC Driver that they put I think it was 15k, 20, 10k but not quite sure I do not have it with me and RC car action said the used something like 5,3,2 in it. so since there was a big difference between the two I went somewhere in the middle which is what I usually run anyways. I guess we will see when it is built, if not I will have to change them[:@]
