RE: need a good esc(NOT HYDRAS)
Your post makes little sense, The number of turns in a brushless motor has no effect on the ESC, furthermore your statement "like everyone says, it's a piece of junk" Is false, if the ESC was setup correctly and ran under spec loads it would not go up in smoke(unless it was defective to start with, in theat case Castle will replace it for free), Castle spends more time and money developing ESC's then ANY other company, if you want to try something better..there is none, if you want the next step down then try a Hacker/Jeti ESC, OEM RC also makes a decent esc.
