RCU Forums - View Single Post - Ryobi 31 conversion
Old 11-04-2007 | 07:49 AM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: Ryobi 31 conversion
You can clean that up easily to make a good motor. If you want more power just take the magneto flywheel and with a dremal grind a keyway for the woddruff key that's about 1/8 inch counter-clock wise from the slot that's there, you'll gain 500 rpm.
The 26 SPEs from BMCA and Brillelli are good also, if you want a rear carb the LS-26 is a good choice.
