RCU Forums - View Single Post - GP Cap 232
Thread: GP Cap 232
Old 11-04-2007 | 03:41 PM
  #1168
Cambo's Avatar
Cambo
Default RE: GP Cap 232
ORIGINAL: bubbagates
Cambo,
Not to sound rude so please do not take it this way. If you are getting the same issues on just about every plane you do as far as the throttle is concerned thgen you may want to consider you throttle setup. You should have sharp curves, you should have no binding and you should be smooth al lthe way through.
Glow engines are more or less tolerable of a not so good setup as the power band is pretty wide, gas engines will suffer to a degree but no being smooth right when you need it because the power band is pretty narrow. It's not uncommon to be at max rpm LONG before the throttle plate is fully open which, depending on you servo arm and throttle stick translation could me you are a full power long before 1/2 stick
Hi bubba, i got out to the field today and was imidiatley told that my throttle setup was not acceptable . I really don't know how GP expects you to set it up using a nylon rod. Anyway, i went to the hardware store a baught some wood so i can mount the servo right behind the firewall wich was suggested my the gasser guys at the field. Should be much better setup than before. I haven't had this happen on all planes, juts planes were the throttle servo was in an obscure place. I usually ended up moving it to fix the problem.
Oh, HEKE yes i pinned the firewall. That was the furst thing i did after the engine came in the mail
