ORIGINAL: idler
is this new keyway indexed counter-clockwise 1/8" while looking at the backside of the flywheel? Assuming this advances the timing a few degrees, how adversly will this affect: starting, low idle, or early part of transition?
Yes, might be a little harder to start. My friend has been doing this for years, he uses a pull rope to start them. When I had a mag on mine I used a regular starter. My friend liked to fainted when he saw me had flip my Ryobi after I converted it to EI, he bought two EIs from LS that day.
ORIGINAL: idler
I'm looking for easy starting, an idle that doesn't shake the glue joints loose, transition without dying, and with enough quiet power to fly a 1/4 sig cub realistically.
EI is the way to go.
