RCU Forums - View Single Post - I got the SHAKES?!
Old 11-05-2007 | 09:36 AM
123Splat
Default RE: I got the SHAKES?!
Ah Shadow,
Now, that's my kinda flying. Use the house instead of reversing the cyclic. Done that many many times! Hence the nickname SPLAT!
One of the easiest things to overlook after "non-lethal smash encounters" is damage to the feathering system (bent feathering spindle, chipped or split o-rings), which can cause all levels of balance/wobble problems. Check this if nothing else seems to be the problem. It isn't always obvious. Also, give the fly-bar and paddle alignment a good look over.
Good Luck,
Spalt
