Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Helimax
 I got the SHAKES?! >
I got the SHAKES?!
Helimax This is for all your Helimax questions and comments.
I got the SHAKES?!
Old 11-04-2007 | 10:25 AM
Default I got the SHAKES?!
Has anyone ever been flying, doing OK, then a puff of wind (when you not expecting it), your heli gets a mind of its own? You try and compensate to the left, to the right, now your getting the shakes (not a good sign). Neighbor's are watching your heli swirl in circles above at 30-50 ft, one notices your leg shaking, "you OK, Rick?" No problem I got this, (the heli was sliding backwards in a large counter-clockwise circle)[X(], added some forward & left cyclic, that stopped the backwards slide, but a gust comes from behind me and next thing I know I flying forward at MACH 1 [X(] (right towards the house)!
It kinda went like "oh S--t, oh s--t, oh s--t, this is gonna leave a mark, SPLAT!" [:@]
Caught the side of the house (cement/asbestos tiles) at about 10', damage is not too bad, plastic blade grip, canopy split near bottom, flybar bent. I straightened out the flybar, fixed the busted blade grip (glad I kept those on), and taped the canopy back together, gave it a test flight in the kitchen, all is OK, but I'm still a little twitchy. I think the shakes were cause by the large Dunkin Donuts coffee this morning before flying, or maybe the crowd of neighbors watching did it.
I know I'm not going back out today (the wind has picked up again), plus I need to switch to "unleaded" beverages for a while.
Is 10:30 too early for that first beer, nah, just preping myself for the NE PATRIOTS vs COLTS game this afternoon.
GO PATS!!
Rick
Old 11-04-2007 | 03:24 PM
Default RE: I got the SHAKES?!
Ok, so I learned another lesson today, lots of caffeine & excitement =THE SHAKES
Not so good for flying, relaxed by raking leaves, winds calmed a little, and I decided I needed a break. Pulled out my AXE CP, and put it on my 2'x2' plywood landing pad, TX on, AXE on, Main armed, tail armed, & away we go...
No SHAKES this time, calm and smooth, although I did notice collective isn't as reponsive, lots of headspeed though. Something is out-of-whack, not sure what, maybe elevator servo is missing some teeth, I'll check in out later.
Rick
Old 11-04-2007 | 07:34 PM
Next time get it on video
Old 11-05-2007 | 09:36 AM
Ah Shadow,
Now, that's my kinda flying. Use the house instead of reversing the cyclic. Done that many many times! Hence the nickname SPLAT!
One of the easiest things to overlook after "non-lethal smash encounters" is damage to the feathering system (bent feathering spindle, chipped or split o-rings), which can cause all levels of balance/wobble problems. Check this if nothing else seems to be the problem. It isn't always obvious. Also, give the fly-bar and paddle alignment a good look over.
Good Luck,
Spalt
