RE: the hyper st PRO thread!
Almost done!!! Just bolted in the motor and pipe and fuel line and was testing the servos and brakes. Had to shim up the motor for the mounts that came with it because it is set up for a starter box and I am using a rotorstart. Just used to nuts to move it up. Found out I put the top of the center diff mounts on backwards and holes for the brake cams were too far away for the brakes to work. Other than that it is going good. Hope to have it running tomorrow night. We'll see.
