RCU Forums - View Single Post - engine downthrust
Old 11-06-2007 | 12:46 AM
bigedmustafa's Avatar
bigedmustafa
Default RE: engine downthrust
Two or three degrees of right thrust and two or three degrees of down thrust is pretty typical. I'd glue the firewall in at two degrees right and down, then you can shim the engine mount if you find you need more later.
