 engine downthrust >
engine downthrust
engine downthrust
Old 11-05-2007 | 05:03 PM
Default engine downthrust
what angle should i set my engine on a high wing trainer. its a sc .75 with aprox 6ft wingspan
Old 11-05-2007 | 05:41 PM
CGRetired's Avatar
Default RE: engine downthrust
Is it an ARF or a kit? Usually the engine thurst angle is already factored in with the firewall construction process.
Old 11-05-2007 | 06:13 PM
its a homebuilt as far as i know and the firewall has been damaged in a crash an i am in the process of rebuilding
Old 11-06-2007 | 12:46 AM
bigedmustafa's Avatar
Two or three degrees of right thrust and two or three degrees of down thrust is pretty typical. I'd glue the firewall in at two degrees right and down, then you can shim the engine mount if you find you need more later.
N429EM's Avatar
2 degrees down and 2 degrees right, makes a good starting point. But, like anything else it may need to be adjusted/trimmed later.
Unless, of course you have a "flying" stabilizer, like the Telemaster.
Old 11-06-2007 | 01:00 AM
OMG E.J.! You're using your Frankenstein Nexstar for your avatar? You are brave!
