RCU Forums - View Single Post - Dymond 52" Tiger Moth Build Thread
Old 11-06-2007 | 01:44 AM
tmulder
My Feedback: (7)
Default RE: Dymond 52" Tiger Moth Build Thread
Here I cut out a template to hold the windscreen while gluing. I used some heavy construction paper and cut it to the pattern I wanted it to have glued to the fuselage. Covering the edges with painters tape to keep the glue from sticking, I then taped it to the fuselage and secured the windscreen to the template and glued using canopy glue. I used windscreen coping by formost products to detail out the windscreen
The last set of pictures shows the final assembly of the cockpit.
ID:	798037   Click image for larger version
ID:	798038   Click image for larger version
ID:	798039   Click image for larger version
ID:	798040   Click image for larger version
ID:	798041   Click image for larger version
