RCU Forums - View Single Post - TREX SE V2 Build Log
Old 11-06-2007 | 01:30 PM
  #82
heliaction's Avatar
heliaction
Default RE: TREX SE V2 Build Log
Can you be sure it is the cyclic servos and not the tail servo. If you were bumping the bench slightly (and i mean ever so slightly) it might cause the tail servo to make those noises. If it is your cyclic servos then i would suggest pulling the screws out, offer the servo to the frame and make sure the wholes line up 100%. Even the slightest bit out will cause the casing to distort.
