RCU Forums - View Single Post - problem on CG for W/H EXTRE 300
Old 11-06-2007 | 02:50 PM
Rush7's Avatar
Rush7
My Feedback: (74)
Default RE: problem on CG for W/H EXTRE 300
You may want to check the incedence on the wings and tail. Just sounds like there is more going on than an issue with the cg.
I have also found that the trim steps can be to large in the radio. You may need to change the distance of the trim steps in your radio to reduce the amount of movement that each step of trim moves the servo.
