WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
problem on CG for W/H EXTRE 300
Old 11-05-2007 | 04:13 PM
Default problem on CG for W/H EXTRE 300
Hi all..........
I have palance the CG for my extra 300 on 3.5" it and wen i flay the plane . It's have tail i have changc the position of the battry to the nose side and it's have have nose wen i fly it its good ..... but it dos not flay strate ...................... litel up and im planing to put a spiner so it well be HAVE HAVE HAVE nose and flay strate or what do you think gays ??
Old 11-05-2007 | 05:39 PM
rctom's Avatar
Default RE: problem on CG for W/H EXTRE 300
It should be balanced on the front half of the wing tube.
TF
Old 11-06-2007 | 06:40 AM
yas
3.5 " is the front haf of the pipe .now it's nos have and still wen i flay the plane it wont go strat it well go up ?? do you think the engin thrust ?? or
3.0 CG is good ??
Old 11-06-2007 | 07:17 AM
when you trim the plane to fly level with the trim on your radio will it fly level? also if you get the plane flying level upright what does it do inverted?
randy
Old 11-06-2007 | 02:50 PM
Rush7's Avatar
My Feedback: (74)
You may want to check the incedence on the wings and tail. Just sounds like there is more going on than an issue with the cg.
I have also found that the trim steps can be to large in the radio. You may need to change the distance of the trim steps in your radio to reduce the amount of movement that each step of trim moves the servo.
