RCU Forums - View Single Post - 4-Stroke Linkage
Old 11-07-2007 | 03:17 PM
Campgems
Default RE: 4-Stroke Linkage
Joel, I have the Magnum 91RFS in my 4*60. From the photos I've seen of the Hobbystar 60, the engine compartment is near identical. My engine has the high speed needle opsite to the exhaust. I use a ball link and a cable for linkage. Using the flexable cable, you can route the linkage around the fuel tank. I battled hard linkage on a couple models before settling on the cable setup. Just keep the amount of cable out of the housing to a minimum and it works really well.
Don
ID:	798910   Click image for larger version
ID:	798911   Click image for larger version
ID:	798912   Click image for larger version
