RE: 4-Stroke Linkage
I use the same system as Custom PC no slop I rotated the Carb 180 degrees, that puts the the needle on the other side (of course the linkage flips to the other side too)
martin
I used the ball joint thing and made the lever from an extra servo arm with one end cut off had what I needed in the extra parts stuff
