RCU Forums - View Single Post - the hyper st PRO thread!
Old 11-07-2007 | 09:21 PM
  #133
vnmsgt's Avatar
vnmsgt
Default RE: the hyper st PRO thread!
Well just ran my new hyper st pro today for the first time since building it and all I can say is WOW!! I can see the difference in buying a car with all the upgrades compared to a rtr. This truggy felt like it was on rails and that is straight out of the box with no tuning or adjustments yet. Just point it to where you want to go and hit the gas and it goes there straight as an arrow! Have to do a little more tuning on the motor since i did not get a chance to run to long tonight due to some minor lighting problems. As far as hitting the jumps, it flies level as a can be and eats up rough sections of the track like you were on a flat surface. I could not believe it. My mantis was all over the place on the bumps but this thing felt like it was cutting through it.
I do have one question or concern:
I need to get it to steer more. I have my settings on my spektrum for the steering turned all the way up to 125% and it does not steer to sharp. With the car off I can turn the wheels with my hand more than the servo is turning them. I know on the steering plate there is 3 different holes for adjusting ackerman but I do not know which hole does what. Right now I have in in the center holes. Where should I put them. Is there also any other adjustment that can make it turn sharper?
