ORIGINAL: DaveG55
ORIGINAL: nick2618
It should spit a little bit of gas not a lot. Once you get the line on it should start. If not you need to start leaning the needles a little until it dose. The pic you posted dose not work and with a couple of good pics someone should be able to tell you what it is and where to put teh needles for ti to start right up.
No, it should not spit out any "gas".
If you're spitting out fuel then you're too rich.
Once properly running and tuned the exhaust will spit some unburnt oil. That is normal and desirable. But there should never be any raw fuel commng from the exhaust.
+1 That truck looks like someone made a chassis and stuck the drive train to it .
