RCU Forums - View Single Post - Triple Telemaster Flies !!
Old 03-31-2003 | 06:16 AM
Russ Verbael
Default Triple Telemaster Flies !!
Yup! No doubt about it, a Telemaster 40 will fly with (3) .40's...
I bought a garage sale Telemaster with a Fox .40 in it and decided to do a twin....but first, since the Fox .40 was already installed, I thought why not build nacelles/lay in a pair of LA .40's and not bother to remove the original Fox engine....(1 plus 2 equals 3 engines!!)
And it worked! The little beast rolled about 10 feet and was airborne at a 60 degree climbout angle. Rolls, loops, stall turns, etc and then back into the landing pattern. A couple of slow flybys for the vultures watching and then a landing followed by a return taxi to the pits.
A second hop confirmed that this was really happening.
Technical stuff: nacelles slung under the wing with individual mini throttle servos and individual 6 oz fuel tanks. Tanks and servos are fully serviceable for fine adjustments. Engines are O.S. LA .40's with 10 x 5 props. Aircraft set up as a tail dragger. CG was set 1" behind the leading edge of the wing. 1100 ma power pack.
So there you have it.
The aircraft went back into the shop and I removed the original Fox engine and stripped everything down for a fresh layer of Monocoat and a return to the flight line as a Twin-Telly.
This multi-engine stuff really is fun.
