RCU Forums - View Single Post - the hyper st PRO thread!
Old 11-09-2007 | 04:27 AM
  #142
wrat's Avatar
wrat
Default RE: the hyper st PRO thread!
[quote]ORIGINAL: vnmsgt
I have it I think one up from the bottom so if I put it on the top hole it would turn the wheels more even with the servo turning the same amount! DUH![:@] I will have to try that. Thanks for the idea. Any other ideas in case does not work which I think it will.
that will be it mate..it will work..put it on the top hole..it will give you the max steering..then set ya epa so it stops just before..canrt go wrong
