RCU Forums - View Single Post - Falcon 3D Tail Problems
Old 11-09-2007 | 05:48 PM
Old Sloppy's Avatar
Old Sloppy
Default RE: Falcon 3D Tail Problems
ORIGINAL: thermal7
On some original driveshafts this keyed end goes limp and the small gear attached to it will not be performing its job. Newer replacement carbon driveshafts are now being manufactured with a more beefier keyed end which is less likey to become damaged from a hard landing or main rotor boom strike. .
Ralph
V1 had a reduced diameter driveshaft end and a 18 amp ESC.
V2 had the larger diameter driveshaft end and a 30 amp ESC.
Harry
