RCU Forums - View Single Post - CMPro On The EDGE 540T
Old 11-10-2007 | 02:04 AM
tonyswsports
Default RE: CMPro On The EDGE 540T
hi every one i also fly CMPRO models & they fly VERY GOOD!!!!
There is many setup u yave to do the book say for normal fly for 3d you yave to move the CG to 30% of the win with the book say 28% for sport fly!!
controls you hav to use at low rate as the book & for 3d as much you can get!!!
my models fly very good as a sport fly & 3d for ex. the cmpro extra .50 with 145cm. win span i use magnum .70rfs & 2 servos at the elev. the CG at the book is 95mm to 100mm the 100mm is not good for this model!! all cmpro hav to recheck the CG at 28% & controls as the book for the 1st fly then after some flights you get some exp. with this model you can move the CG to 30% & controls at maximum!!
