ORIGINAL: fliprob17
With an all up weight between 80-88oz, and looking for some crazy power around 200watts per pound at WOT, you are looking in the range of 1,000-1,100 total watts. Using the TP3850-5SV - V2 5s Extreme Series 18.5volt, somewhere around 65amps should do the trick. An incredible power to weight ratio.
About the same as a good .46 on 10%, huh?
Flame suit on....
