RE: Toro 25 prop hub
Yes this is the Taube 90. The kit was easy to build. The engine mounted with a 25cc Homie very easy. The only mod I did was to make sure that the control rods for the elev. are supported outside the fuse. Thats because the rod is so long after it comes out of the fuse that it will bend & you will have no elev. control. I used nirod tube & then inserted piano wire inside. I have some other pics if you need.
