Guys, check out the features of the 'Professional' Amax Thwarter.
Front / rear differentials with good quality bevel gear as well as with 5 screws are quite easy for maintenance.
Fuel tank with vast capacity, easily to refuel with super calibre, prevent overflowing and leaking;
Front/rear umbrella gear differential and differential box with leak protection;
With 13.8g super-light-weight fly wheel, make the engine smaller in load;
Adrustable-bounce, make spring buffered ;
Differential with 5pcs of screw only, fixing/disasembling is easy;
The all-metal disc type brakes and super thick asbestos brake block;
Flexuose 6061/T6 aluminum chassis, thickness:2.5mm;
Aluminum alloy in 6061, Anodic heavy-duty adrustor;
Extra large 75cc leak proof fuel tank with overflow pipe and spring load fill cover for quick re-filling.
Eight oil filled shock absorbers provide excellent shock protection.
Pre-mounted 1/10th scale monster truck tires provide a long service period and are perfect for runing on any riough surface ground.
Double sponge filter, dustproof result is better. 7.5mm oversize gas vent;
56mm resonance
BWAHAHAHAHAHAHAHAHAHAHA!!!
Seriously dude, you don't want this car. What's wrong with something like this?
http://cgi.ebay.com/OFNA-HYPER-7-PBS...QQcmdZViewItem
