RCU Forums - View Single Post - GP Easy Sport 40 Bashing
Old 11-11-2007 | 01:02 AM
UkerDuker's Avatar
UkerDuker
Default RE: Bashing question
After some thinking (no laughing), I have decided I will do this. This should make for an interesting side project as I assemble my 1/12" scale AC-130.
Personally I hate having perfectly good engines laying around.... these need to be put to good use.
Tonight I got the majority of the fuselage assembled. I plan to go with a tricycle landing gear setup. I moved the main(aft) gear blocks back approx 1" to give me stability for ground ops.
I plan to mount my 2400 6v battery up front where the original engine was called for. This should be a good start to balancing this project. I will also shift all possible electronics closer to the nose.
I plan to keep everything close to "stock" as called for by the kit.
Mike
Maybe I can add the OS .50 I have laying around in the nose?!!?!?!?!? nah, better not.
