RCU Forums - View Single Post - AAHHH Crap! Pushrod troubles, please help..
Old 11-11-2007 | 05:30 PM
Sarges_heroes2003's Avatar
Sarges_heroes2003
Default AAHHH Crap! Pushrod troubles, please help..
Well a little info on what im having trouble with here. I have a Alpha .60 BARF that im putting together and the rudder push rod was a little to long. I had the servo turned around so the "arm end" was pointing to the nose but it still wasn't close enough. I tried screwing on the little plastic clevis as far as it would go but it was still a little to long. I am trying to get the rod to go to the screw on the servo arm (for length) but its so long it completely over shot the servo. there is only one easy clevis in the kit, despite the manual showing three. So I measured, and tried to use some Z-bend Pliers on it and the dang thing snapped in two!!! [:@]
Now im in a pickle. I can buy a new push rod set but with out a way to secure them to the servo arm I will be in the same boat. [X(]
My question is, if it were YOU what connector would you buy? a easy clevis? or some thing else?[X(]
P.S. Several of the rods came with a 90 degree angle bent into it, and intended the snap on plastic links to be used there. How do they get the 90 degree bend in 4-40 wire??[&:]
