RCU Forums - View Single Post - Contact info in plane!
Old 04-01-2003 | 03:22 AM
Tippie
Default Contact info in plane!
Wait till he gets behind the wheel of your car!!! As far as the info in the plane, the AMA sells a "AMA ID Label" which is $1.25 for 10 that has a fuel proof adhesive back (webstore/patchs and decals). It is a requirement of the AMA safety code that you have some type of ID with you name/address and phone number affixed to the plane and your AMA number on the plane, generally it is on the upper side of the right wing. That is per the AMA safety code, general section, paragraph 5. SIG used to put one in every kit box, haven't brought one of their kits in quite some time so don't know that is still true (wasn't sticky back though). In any case I'm glad to hear you got the plane back so you can experience the 10 minutes of pleasure and 1 minute of panic again. By the way you need at least 8 rubber bands holding the wing, two on each side and four crossed over (2 each way).
