RE: Plan Transfer - Help
I've heard you can print using a laser printer (which uses toner) in reverse and then place the paper face down on the wood and iron it. This transfers the toner to the balsa.
You can also make a master template out of hardwood (or even aluminum) and then use that to cut the balsa (for example, the ribs).
