RCU Forums - View Single Post - What balsa plane for hacker a20-20l ?
Old 11-13-2007 | 12:01 AM
lwatson's Avatar
lwatson
Default RE: What balsa plane for hacker a20-20l ?
I would also recommend the mini-inspire, or another good plane would be the fliton prodigy, but it flies better with a 1320 pack. You should get very good flight times on that set up, it depends how large a prop you use and how far you push it, but 10-12 min easily. HS-55's are good on either plane.
Larry
