RCU Forums - View Single Post - Brushless recomendations for a Mini Slinger
Old 11-15-2007 | 06:30 AM
Spid
Default RE: Brushless recomendations for a Mini Slinger
ORIGINAL: Learning2Fly
Kevin thanks for the response. Sounds just like what I'm looking for. Did you just mount it in the standard set up and did you have to cut a hole in the hatch for cooling? I may even try to get this up and running in the next couple of weeks. Thanks again.
Scot
Hi Scot,
I used the standard mounting but roughed up the plastic with some sandpaper and epoxied the motor in. I did not cut any holes in for cooling but you could if you wanted to, wouldn't hurt a thing.
I see you are in Elyria, I'm in North Olmsted, where do you fly at?
