RCU Forums - View Single Post - Tail rotor not centering
Old 11-15-2007 | 09:19 AM
BryFlyGuy67's Avatar
BryFlyGuy67
Default RE: Tail rotor not centering
This threw me too when I first setup my tail and servo. As stated above, you can cause the servo to re-center by moving the rudder stick rapidly back and forth and then letting go. You can also put your gyro in rate mode (if you have that set up) and you can see the center that way.
