RE: new Arf Boomerang 14lb thrust
I want to add that the piston i used comes from an older water braking system and now that i see the Eurokit pump it looks to me that it might have
a too small movement. I will have to send them an email prior to ordering it.
You can always use an insulin syringe instead and from what i hear this is what many others have done.
Update: Watching more carefully the Eurokit pump will do. You can adjust the travel anyway by pre pressurizing the oil circuit.
Chris
