RE: adapters and current flow
tamiya connectors have more resistance than Deans or Traxxas connectors. the more resistance, the less current can flow. and if too much current flows, the connectors can actually melt! so i would suggest switching all plugs to Deans or Traxxas. if you are comfortable with soldering, use deans. if you have no experience with a soldering iron, use the new traxxas ones, as they dont need soldering.
you will find that your vehicle feels more "punchy" as a result of lower resistance, switching the connectors is going to be very worth while versus using a temporary adaptor.
