RCU Forums - View Single Post - Solo's upgrades
Old 11-17-2007 | 02:14 AM
rccrasher9
Default RE: Solo's upgrades
Hi all, well I installed the xtreme 180's and used stock blades with stock batt and it flies heavy... usually with stock motors I can hover at 1/2 stick. I'm actually 3 clicks higher with new motors.... [X(][:@] I need to break motors in.... HOW do you do that?..... or is it too late..... I hovered for about 3 min... hopefully with the smc 800mah 22c, micro heli alum blade holders and xtreme blades I'll get better hover for the juice....I'll get those hopefully in the morning......Then I will see what alot of you are talking about....
SO HOW DO YOU BREAKE IN A EXTREME 180 motor?
I also lost [X(] which motor was which... I installed the wires on the rx the same way the old ones came off and made sure they turn the same direction... hope thats enough.
Joe
