RCU Forums - View Single Post - Hanger 9 Aresti Garbage!!!
Old 07-30-2003 | 08:33 PM
bgi
My Feedback: (7)
Default Hanger 9 Aresti Garbage!!!
dcknowles, the flying wires go from fin to stab to bottom of fuse. There is typically a small #2 bolt on the fin and each side of the stab. In this photo, I used #2 screw and #2 solder clevises with 2-56 end-threaded rod. One end is soldered, the other is adjustable. The clevises have had the "pin side" arm cut off with a dremel. The other "arm" has had it's hold drilled out a tad to fit the #2 screw. On the bottom of the fuse, I simply screwed through the clevis arm into the fuse.
See the photo below of my SIG SE (yea, it's not a good wire demo photo, but it works)
Hey guys, my Aresti is fine with no flying wires. Maybe I'll add some?
